Time Before: 0.02866 seconds
Time After: 0.03560 seconds
Time Taken: 0.00694 seconds
Time Before: 0.03568 seconds
Time After: 0.03614 seconds
Time Before: 0.03638 seconds
Time After: 0.03651 seconds
Time Before: 0.03731 seconds
Time After: 0.03947 seconds
Time Taken: 0.00217 seconds
Time Before: 0.03659 seconds
Time After: 0.04351 seconds
Time Taken: 0.00692 seconds
Time Before: 0.05198 seconds
Time After: 0.05237 seconds
Time Before: 0.05495 seconds
Time After: 0.05615 seconds
Time Before: 0.05136 seconds
Time After: 0.05634 seconds
Time Taken: 0.00498 seconds
Time Before: 0.10028 seconds
Time After: 0.10041 seconds
Time Before: 0.12011 seconds
Time After: 0.12135 seconds
End call of global.php: 0.12340188026428
Time Before: 0.13208 seconds
Time After: 0.13224 seconds
Time Before: 0.13471 seconds
Time After: 0.13614 seconds
SET lastactivity = 1776727504, location = '/forums/private.php?do=newpm&explain=1&u=134999', badlocation = 1
Time Before: 0.15449 seconds
Time After: 0.15479 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.15344595909119 seconds with 9 queries, spending 0.0076229572296143 doing MySQL queries and 0.14582300186157 doing PHP things.
