Time Before: 0.00150 seconds
Time After: 0.00206 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00213 seconds
Time After: 0.00256 seconds
Time Before: 0.00278 seconds
Time After: 0.00289 seconds
Time Before: 0.00373 seconds
Time After: 0.00674 seconds
Time Taken: 0.00301 seconds
Time Before: 0.00294 seconds
Time After: 0.01212 seconds
Time Taken: 0.00919 seconds
Time Before: 0.01387 seconds
Time After: 0.01432 seconds
Time Before: 0.01673 seconds
Time After: 0.01801 seconds
Time Before: 0.01332 seconds
Time After: 0.01820 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02340 seconds
Time After: 0.02352 seconds
Time Before: 0.02581 seconds
Time After: 0.02711 seconds
Time Before: 0.03050 seconds
Time After: 0.03069 seconds
Time Before: 0.03313 seconds
Time After: 0.03466 seconds
Time Taken: 0.00153 seconds
UPDATE session SET lastactivity = 1785385277, location = '/forums/private.php?do=newpm&explain=1&u=135009', badlocation = 1 WHERE sessionhash = '1b43d45bbaaa70ba8be59b846adc9cfa'
Time Before: 0.04984 seconds
Time After: 0.05014 seconds
