Time Before: 0.01660 seconds
Time After: 0.02526 seconds
Time Taken: 0.00866 seconds
Time Before: 0.02539 seconds
Time After: 0.02580 seconds
Time Before: 0.02603 seconds
Time After: 0.02617 seconds
Time Before: 0.02702 seconds
Time After: 0.03025 seconds
Time Taken: 0.00322 seconds
Time Before: 0.02627 seconds
Time After: 0.03426 seconds
Time Taken: 0.00799 seconds
Time Before: 0.04422 seconds
Time After: 0.04461 seconds
Time Before: 0.04670 seconds
Time After: 0.04790 seconds
Time Before: 0.04346 seconds
Time After: 0.04816 seconds
Time Taken: 0.00470 seconds
Time Before: 0.08849 seconds
Time After: 0.08863 seconds
Time Before: 0.10441 seconds
Time After: 0.10568 seconds
Time Before: 0.11703 seconds
Time After: 0.11717 seconds
Time Before: 0.11975 seconds
Time After: 0.12148 seconds
Time Taken: 0.00173 seconds
UPDATE session SET lastactivity = 1776799864, location = '/forums/private.php?do=newpm&explain=1&u=135052', badlocation = 1 WHERE sessionhash = '84d505ff74940a4d05f0ae95a61eba7a'
Time Before: 0.14468 seconds
Time After: 0.14498 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
