Time Before: 0.02180 seconds
Time After: 0.02755 seconds
Time Taken: 0.00575 seconds
Time Before: 0.02762 seconds
Time After: 0.02800 seconds
Time Before: 0.02820 seconds
Time After: 0.02834 seconds
Time Before: 0.02914 seconds
Time After: 0.03232 seconds
Time Taken: 0.00318 seconds
Time Before: 0.02840 seconds
Time After: 0.03681 seconds
Time Taken: 0.00841 seconds
Time Before: 0.04721 seconds
Time After: 0.04742 seconds
Time Before: 0.05061 seconds
Time After: 0.05180 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.04648 seconds
Time After: 0.05204 seconds
Time Taken: 0.00556 seconds
Memory After: 2,261.820 KB
Time Before: 0.08635 seconds
Time After: 0.08650 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.10710 seconds
Time After: 0.10833 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.1103048324585
Time Before: 0.11957 seconds
Time After: 0.11974 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.12203 seconds
Time After: 0.12353 seconds
Time Taken: 0.00150 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789142959, location = '/forums/private.php?do=newpm&explain=1&u=135079', badlocation = 1
Time Before: 0.14022 seconds
Time After: 0.14060 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.13921689987183 seconds with 9 queries, spending 0.0085101127624512 doing MySQL queries and 0.13070678710938 doing PHP things.
