Time Before: 0.00167 seconds
Time After: 0.00228 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00235 seconds
Time After: 0.00282 seconds
Time Before: 0.00312 seconds
Time After: 0.00329 seconds
Time Before: 0.00419 seconds
Time After: 0.00675 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00339 seconds
Time After: 0.01177 seconds
Time Taken: 0.00837 seconds
Time Before: 0.01366 seconds
Time After: 0.01407 seconds
Time Before: 0.01644 seconds
Time After: 0.01763 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01305 seconds
Time After: 0.01787 seconds
Time Taken: 0.00482 seconds
Time Before: 0.02354 seconds
Time After: 0.02374 seconds
Time Before: 0.02595 seconds
Time After: 0.02724 seconds
End call of global.php: 0.030030965805054
Time Before: 0.03143 seconds
Time After: 0.03156 seconds
Time Before: 0.03369 seconds
Time After: 0.03517 seconds
SET lastactivity = 1780615614, location = '/forums/private.php?do=newpm&explain=1&u=135115', badlocation = 1
WHERE sessionhash = '295cc732df117534f65c11ae631a16f6'
Time Before: 0.04861 seconds
Time After: 0.05275 seconds
Time Taken: 0.00414 seconds
Page generated in 0.04767894744873 seconds with 9 queries, spending 0.012030363082886 doing MySQL queries and 0.035648584365845 doing PHP things.
