Time Before: 0.02088 seconds
Time After: 0.02965 seconds
Time Taken: 0.00876 seconds
Memory Before: 534.492 KB
Memory After: 559.609 KB
Time Before: 0.02974 seconds
Time After: 0.03012 seconds
Memory Before: 559.547 KB
Memory After: 560.555 KB
Time Before: 0.03036 seconds
Time After: 0.03049 seconds
Memory Before: 561.109 KB
Memory After: 561.633 KB
Time Before: 0.03139 seconds
Time After: 0.03367 seconds
Time Taken: 0.00228 seconds
Memory Before: 564.234 KB
Memory After: 565.156 KB
Time Before: 0.03055 seconds
Time After: 0.03879 seconds
Time Taken: 0.00824 seconds
Memory Before: 560.883 KB
Memory After: 1,641.883 KB
Memory Used: 1,081.000 KB
Time Before: 0.04870 seconds
Time After: 0.04913 seconds
Memory Before: 2,136.727 KB
Memory After: 2,137.344 KB
Time Before: 0.05249 seconds
Time After: 0.05367 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,148.789 KB
Memory After: 2,148.648 KB
Time Before: 0.04796 seconds
Time After: 0.05393 seconds
Time Taken: 0.00597 seconds
Memory Before: 2,128.906 KB
Memory After: 2,261.672 KB
Time Before: 0.07890 seconds
Time After: 0.07902 seconds
Memory Before: 2,815.242 KB
Memory After: 2,815.758 KB
Time Before: 0.10069 seconds
Time After: 0.10192 seconds
Memory Before: 2,903.539 KB
Memory After: 2,904.133 KB
End call of global.php: 0.10379791259766
Time Before: 0.11305 seconds
Time After: 0.11321 seconds
Memory Before: 3,540.344 KB
Memory After: 3,540.773 KB
Time Before: 0.11659 seconds
Time After: 0.11806 seconds
Memory Before: 3,821.875 KB
Memory After: 3,823.563 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=135166'
Time Before: 0.13584 seconds
Time After: 0.13612 seconds
Memory Before: 4,295.492 KB
Memory After: 4,295.734 KB
Page generated in 0.13483309745789 seconds with 9 queries, spending 0.0076808929443359 doing MySQL queries and 0.12715220451355 doing PHP things.
