Time Before: 0.02059 seconds
Time After: 0.02814 seconds
Time Taken: 0.00755 seconds
Time Before: 0.02825 seconds
Time After: 0.02866 seconds
Time Before: 0.02893 seconds
Time After: 0.02907 seconds
Time Before: 0.02979 seconds
Time After: 0.03203 seconds
Time Taken: 0.00225 seconds
Time Before: 0.02915 seconds
Time After: 0.03616 seconds
Time Taken: 0.00701 seconds
Time Before: 0.04474 seconds
Time After: 0.04516 seconds
Time Before: 0.04660 seconds
Time After: 0.04775 seconds
Time Taken: 0.00115 seconds
Time Before: 0.04413 seconds
Time After: 0.04796 seconds
Time Taken: 0.00383 seconds
Time Before: 0.07525 seconds
Time After: 0.07543 seconds
Time Before: 0.09268 seconds
Time After: 0.09396 seconds
Time Before: 0.10178 seconds
Time After: 0.10197 seconds
Time Before: 0.10530 seconds
Time After: 0.10681 seconds
Time Taken: 0.00151 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=135195', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12437 seconds
Time After: 0.12464 seconds
