Time Before: 0.01746 seconds
Time After: 0.02143 seconds
Time Taken: 0.00397 seconds
Time Before: 0.02154 seconds
Time After: 0.02282 seconds
Time Before: 0.02323 seconds
Time After: 0.02343 seconds
Time Before: 0.02432 seconds
Time After: 0.02708 seconds
Time Taken: 0.00276 seconds
Time Before: 0.02352 seconds
Time After: 0.03202 seconds
Time Taken: 0.00850 seconds
Time Before: 0.03845 seconds
Time After: 0.03883 seconds
Time Before: 0.04114 seconds
Time After: 0.04281 seconds
Time Taken: 0.00167 seconds
Time Before: 0.03771 seconds
Time After: 0.04307 seconds
Time Taken: 0.00536 seconds
Time Before: 0.07279 seconds
Time After: 0.07298 seconds
Time Before: 0.08267 seconds
Time After: 0.08404 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.085932970046997
Time Before: 0.09165 seconds
Time After: 0.09187 seconds
Time Before: 0.09502 seconds
Time After: 0.09653 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1772947749, location = '/forums/private.php?do=newpm&explain=1&u=135211'
WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.11387 seconds
Time After: 0.11415 seconds
Page generated in 0.11266303062439 seconds with 9 queries, spending 0.0098588466644287 doing MySQL queries and 0.10280418395996 doing PHP things.
