Time Before: 0.01392 seconds
Time After: 0.01731 seconds
Time Taken: 0.00339 seconds
Time Before: 0.01743 seconds
Time After: 0.01790 seconds
Time Before: 0.01816 seconds
Time After: 0.01829 seconds
Time Before: 0.01912 seconds
Time After: 0.02181 seconds
Time Taken: 0.00269 seconds
Time Before: 0.01836 seconds
Time After: 0.02685 seconds
Time Taken: 0.00849 seconds
Time Before: 0.03162 seconds
Time After: 0.03205 seconds
Time Before: 0.03479 seconds
Time After: 0.03606 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03072 seconds
Time After: 0.03627 seconds
Time Taken: 0.00555 seconds
Memory After: 2,261.820 KB
Time Before: 0.06042 seconds
Time After: 0.06060 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.07056 seconds
Time After: 0.07184 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.08052 seconds
Time After: 0.08069 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.08353 seconds
Time After: 0.08568 seconds
Time Taken: 0.00215 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789128378, location = '/forums/private.php?do=newpm&explain=1&u=135235', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.10192 seconds
Time After: 0.10228 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
