Time Before: 0.00316 seconds
Time After: 0.00411 seconds
Time Taken: 0.00095 seconds
Time Before: 0.00421 seconds
Time After: 0.00465 seconds
Time Before: 0.00491 seconds
Time After: 0.00504 seconds
Time Before: 0.00592 seconds
Time After: 0.00832 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00511 seconds
Time After: 0.01323 seconds
Time Taken: 0.00812 seconds
Time Before: 0.01527 seconds
Time After: 0.01565 seconds
Time Before: 0.01862 seconds
Time After: 0.01991 seconds
Time Before: 0.01452 seconds
Time After: 0.02015 seconds
Time Taken: 0.00564 seconds
Time Before: 0.02701 seconds
Time After: 0.02713 seconds
Time Before: 0.02963 seconds
Time After: 0.03091 seconds
End call of global.php: 0.033570051193237
Time Before: 0.03495 seconds
Time After: 0.03510 seconds
Time Before: 0.03788 seconds
Time After: 0.03949 seconds
Time Taken: 0.00160 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=135251', badlocation = 1
Time Before: 0.05614 seconds
Time After: 0.05640 seconds
Page generated in 0.055133104324341 seconds with 9 queries, spending 0.0080654621124268 doing MySQL queries and 0.047067642211914 doing PHP things.
