Time Before: 0.02626 seconds
Time After: 0.03260 seconds
Time Taken: 0.00633 seconds
Time Before: 0.03271 seconds
Time After: 0.03327 seconds
Time Taken: 0.00056 seconds
Time Before: 0.03357 seconds
Time After: 0.03372 seconds
Time Before: 0.03442 seconds
Time After: 0.03631 seconds
Time Taken: 0.00189 seconds
Time Before: 0.03377 seconds
Time After: 0.04011 seconds
Time Before: 0.05111 seconds
Time After: 0.05155 seconds
Time Before: 0.05394 seconds
Time After: 0.05514 seconds
Time Before: 0.05034 seconds
Time After: 0.05535 seconds
Time Taken: 0.00501 seconds
Time Before: 0.09838 seconds
Time After: 0.09857 seconds
Time Before: 0.11687 seconds
Time After: 0.11813 seconds
End call of global.php: 0.12021589279175
Time Before: 0.12789 seconds
Time After: 0.12806 seconds
Time Before: 0.13061 seconds
Time After: 0.13206 seconds
SET lastactivity = 1776521901, location = '/forums/private.php?do=newpm&explain=1&u=135263'
Time Before: 0.15443 seconds
Time After: 0.15474 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.15337204933167 seconds with 9 queries, spending 0.007615327835083 doing MySQL queries and 0.14575672149658 doing PHP things.
