Time Before: 0.00224 seconds
Time After: 0.00339 seconds
Time Taken: 0.00115 seconds
Time Before: 0.00346 seconds
Time After: 0.00384 seconds
Time Before: 0.00402 seconds
Time After: 0.00412 seconds
Time Before: 0.00476 seconds
Time After: 0.00688 seconds
Time Taken: 0.00212 seconds
Time Before: 0.00417 seconds
Time After: 0.01025 seconds
Time Taken: 0.00608 seconds
Time Before: 0.01191 seconds
Time After: 0.01224 seconds
Time Before: 0.01524 seconds
Time After: 0.01639 seconds
Time Before: 0.01138 seconds
Time After: 0.01657 seconds
Time Taken: 0.00518 seconds
Time Before: 0.02160 seconds
Time After: 0.02176 seconds
Time Before: 0.02345 seconds
Time After: 0.02471 seconds
End call of global.php: 0.026349067687988
Time Before: 0.02757 seconds
Time After: 0.02771 seconds
Time Before: 0.03036 seconds
Time After: 0.03206 seconds
Time Taken: 0.00170 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=135273'
Time Before: 0.04492 seconds
Time After: 0.04520 seconds
Page generated in 0.043997049331665 seconds with 9 queries, spending 0.0076084136962891 doing MySQL queries and 0.036388635635376 doing PHP things.
