Time Before: 0.01845 seconds
Time After: 0.02276 seconds
Time Taken: 0.00430 seconds
Memory Before: 1,244.094 KB
Memory After: 1,270.898 KB
Time Before: 0.02285 seconds
Time After: 0.02333 seconds
Memory Before: 1,270.859 KB
Memory After: 1,271.836 KB
Time Before: 0.02362 seconds
Time After: 0.02376 seconds
Memory Before: 1,272.477 KB
Memory After: 1,273.000 KB
Time Before: 0.02449 seconds
Time After: 0.02681 seconds
Time Taken: 0.00232 seconds
Memory Before: 1,275.867 KB
Memory After: 1,276.789 KB
Time Before: 0.02381 seconds
Time After: 0.03093 seconds
Time Taken: 0.00712 seconds
Memory Before: 1,272.281 KB
Memory After: 2,353.516 KB
Memory Used: 1,081.234 KB
Time Before: 0.03729 seconds
Time After: 0.03777 seconds
Memory Before: 2,893.773 KB
Memory After: 2,894.391 KB
Time Before: 0.04021 seconds
Time After: 0.04156 seconds
Time Taken: 0.00135 seconds
Memory Before: 2,906.219 KB
Memory After: 2,906.078 KB
Time Before: 0.03656 seconds
Time After: 0.04187 seconds
Time Taken: 0.00531 seconds
Memory Before: 2,886.500 KB
Memory After: 3,019.500 KB
Memory Used: 133.000 KB
Time Before: 0.07715 seconds
Time After: 0.07733 seconds
Memory Before: 3,654.063 KB
Memory After: 3,654.578 KB
Time Before: 0.12781 seconds
Time After: 0.12903 seconds
Memory Before: 4,131.688 KB
Memory After: 4,132.281 KB
End call of global.php: 0.13132691383362
Time Before: 0.15663 seconds
Time After: 0.15684 seconds
Memory Before: 5,195.945 KB
Memory After: 5,324.289 KB
Time Before: 0.16198 seconds
Time After: 0.16349 seconds
Time Taken: 0.00151 seconds
Memory Before: 5,479.641 KB
Memory After: 5,609.242 KB
SET lastactivity = 1773116913, location = '/forums/private.php?do=newpm&explain=1&u=135302', badlocation = 1
WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.18964 seconds
Time After: 0.18996 seconds
Memory Before: 6,009.117 KB
Memory After: 6,009.328 KB
Page generated in 0.18860483169556 seconds with 9 queries, spending 0.0082080364227295 doing MySQL queries and 0.18039679527283 doing PHP things.
