Time Before: 0.02583 seconds
Time After: 0.03389 seconds
Time Taken: 0.00806 seconds
Time Before: 0.03400 seconds
Time After: 0.03442 seconds
Time Before: 0.03474 seconds
Time After: 0.03495 seconds
Time Before: 0.03559 seconds
Time After: 0.03883 seconds
Time Taken: 0.00324 seconds
Time Before: 0.03502 seconds
Time After: 0.04279 seconds
Time Taken: 0.00776 seconds
Time Before: 0.04874 seconds
Time After: 0.04934 seconds
Time Taken: 0.00060 seconds
Time Before: 0.05055 seconds
Time After: 0.05181 seconds
Time Before: 0.04785 seconds
Time After: 0.05199 seconds
Time Taken: 0.00413 seconds
Time Before: 0.09456 seconds
Time After: 0.09474 seconds
Time Before: 0.11702 seconds
Time After: 0.11828 seconds
Time Before: 0.13008 seconds
Time After: 0.13027 seconds
Time Before: 0.13299 seconds
Time After: 0.13453 seconds
Time Taken: 0.00154 seconds
UPDATE session SET lastactivity = 1784881368, location = '/forums/private.php?do=newpm&explain=1&u=135315', badlocation = 1 WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.15082 seconds
Time After: 0.15110 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
