Time Before: 0.01969 seconds
Time After: 0.02470 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02478 seconds
Time After: 0.02520 seconds
Time Before: 0.02548 seconds
Time After: 0.02562 seconds
Time Before: 0.02662 seconds
Time After: 0.02895 seconds
Time Taken: 0.00233 seconds
Time Before: 0.02570 seconds
Time After: 0.03274 seconds
Time Taken: 0.00704 seconds
Time Before: 0.04216 seconds
Time After: 0.04258 seconds
Time Before: 0.04417 seconds
Time After: 0.04535 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04141 seconds
Time After: 0.04556 seconds
Time Taken: 0.00415 seconds
Time Before: 0.07599 seconds
Time After: 0.07613 seconds
Time Before: 0.09663 seconds
Time After: 0.09786 seconds
Time Before: 0.11295 seconds
Time After: 0.11342 seconds
Time Before: 0.11672 seconds
Time After: 0.11861 seconds
Time Taken: 0.00188 seconds
UPDATE session SET lastactivity = 1788884455, location = '/forums/private.php?do=newpm&explain=1&u=135347' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.13858 seconds
Time After: 0.13907 seconds
