Time Before: 0.00149 seconds
Time After: 0.00207 seconds
Time Taken: 0.00058 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00214 seconds
Time After: 0.00272 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00312 seconds
Time After: 0.00328 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00443 seconds
Time After: 0.00826 seconds
Time Taken: 0.00383 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00335 seconds
Time After: 0.01314 seconds
Time Taken: 0.00979 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01491 seconds
Time After: 0.01531 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01837 seconds
Time After: 0.01962 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.01429 seconds
Time After: 0.01984 seconds
Time Taken: 0.00556 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.02570 seconds
Time After: 0.02586 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.02768 seconds
Time After: 0.02894 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
End call of global.php: 0.030576944351196
Time Before: 0.03181 seconds
Time After: 0.03198 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.03401 seconds
Time After: 0.03574 seconds
Time Taken: 0.00173 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
SET lastactivity = 1789019602, location = '/forums/private.php?do=newpm&explain=1&u=135357'
Time Before: 0.04986 seconds
Time After: 0.05023 seconds
Memory Before: 4,918.805 KB
Memory After: 4,919.031 KB
Page generated in 0.048970937728882 seconds with 9 queries, spending 0.0099179744720459 doing MySQL queries and 0.039052963256836 doing PHP things.
