Time Before: 0.01630 seconds
Time After: 0.01924 seconds
Time Taken: 0.00294 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01935 seconds
Time After: 0.01994 seconds
Time Taken: 0.00059 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02017 seconds
Time After: 0.02030 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02116 seconds
Time After: 0.02338 seconds
Time Taken: 0.00222 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02038 seconds
Time After: 0.02753 seconds
Time Taken: 0.00715 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03502 seconds
Time After: 0.03521 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03785 seconds
Time After: 0.03903 seconds
Time Taken: 0.00118 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.03433 seconds
Time After: 0.03926 seconds
Time Taken: 0.00494 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.06921 seconds
Time After: 0.06935 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.10904 seconds
Time After: 0.11030 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.11252999305725
Time Before: 0.13409 seconds
Time After: 0.13422 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.13773 seconds
Time After: 0.14001 seconds
Time Taken: 0.00228 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1773110263, location = '/forums/private.php?do=newpm&explain=1&u=135369', badlocation = 1
WHERE sessionhash = '8385044bee7d6de684cfeaf823df6777'
Time Before: 0.16034 seconds
Time After: 0.16058 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.15929317474365 seconds with 9 queries, spending 0.0083596706390381 doing MySQL queries and 0.15093350410461 doing PHP things.
