Time Before: 0.02807 seconds
Time After: 0.03558 seconds
Time Taken: 0.00751 seconds
Time Before: 0.03567 seconds
Time After: 0.03610 seconds
Time Before: 0.03637 seconds
Time After: 0.03653 seconds
Time Before: 0.03742 seconds
Time After: 0.03932 seconds
Time Taken: 0.00189 seconds
Time Before: 0.03661 seconds
Time After: 0.04353 seconds
Time Taken: 0.00692 seconds
Time Before: 0.05214 seconds
Time After: 0.05237 seconds
Time Before: 0.05480 seconds
Time After: 0.05599 seconds
Time Before: 0.05137 seconds
Time After: 0.05622 seconds
Time Taken: 0.00485 seconds
Time Before: 0.09419 seconds
Time After: 0.09435 seconds
Time Before: 1.50445 seconds
Time After: 1.50634 seconds
End call of global.php: 1.509113073349
Time Before: 1.51804 seconds
Time After: 1.51820 seconds
Time Before: 1.52147 seconds
Time After: 1.52304 seconds
Time Taken: 0.00157 seconds
SET lastactivity = 1789052516, location = '/forums/private.php?do=newpm&explain=1&u=135396'
Time Before: 1.54163 seconds
Time After: 1.54188 seconds
Page generated in 1.5405220985413 seconds with 9 queries, spending 0.0079472064971924 doing MySQL queries and 1.5325748920441 doing PHP things.
