Time Before: 0.01229 seconds
Time After: 0.01694 seconds
Time Taken: 0.00465 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01704 seconds
Time After: 0.01748 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.01767 seconds
Time After: 0.01778 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.01852 seconds
Time After: 0.02119 seconds
Time Taken: 0.00267 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.01785 seconds
Time After: 0.02503 seconds
Time Taken: 0.00718 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03026 seconds
Time After: 0.03078 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03269 seconds
Time After: 0.03391 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.02949 seconds
Time After: 0.03413 seconds
Time Taken: 0.00464 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.06680 seconds
Time After: 0.06695 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.23949 seconds
Time After: 0.24069 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.24302196502686
Time Before: 0.25940 seconds
Time After: 0.25964 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.26375 seconds
Time After: 0.26522 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1772685102, location = '/forums/private.php?do=newpm&explain=1&u=135426', badlocation = 1
Time Before: 0.28681 seconds
Time After: 0.28714 seconds
Memory Before: 5,999.000 KB
Memory After: 5,999.211 KB
Page generated in 0.28543591499329 seconds with 9 queries, spending 0.0083456039428711 doing MySQL queries and 0.27709031105042 doing PHP things.
