Time Before: 0.02061 seconds
Time After: 0.02746 seconds
Time Taken: 0.00685 seconds
Time Before: 0.02756 seconds
Time After: 0.02798 seconds
Time Before: 0.02824 seconds
Time After: 0.02836 seconds
Time Before: 0.02920 seconds
Time After: 0.03112 seconds
Time Taken: 0.00192 seconds
Time Before: 0.02843 seconds
Time After: 0.03690 seconds
Time Taken: 0.00848 seconds
Time Before: 0.04883 seconds
Time After: 0.04925 seconds
Time Before: 0.05253 seconds
Time After: 0.05375 seconds
Memory Before: 2,148.836 KB
Memory After: 2,148.695 KB
Time Before: 0.04817 seconds
Time After: 0.05402 seconds
Time Taken: 0.00584 seconds
Memory After: 2,261.719 KB
Time Before: 0.09052 seconds
Time After: 0.09071 seconds
Memory Before: 2,815.297 KB
Memory After: 2,815.813 KB
Time Before: 0.10879 seconds
Time After: 0.11012 seconds
Time Taken: 0.00133 seconds
Memory Before: 2,903.500 KB
Memory After: 2,904.094 KB
Time Before: 0.12205 seconds
Time After: 0.12223 seconds
Memory Before: 3,540.289 KB
Memory After: 3,540.719 KB
Time Before: 0.12458 seconds
Time After: 0.12614 seconds
Time Taken: 0.00156 seconds
Memory Before: 3,821.844 KB
Memory After: 3,823.531 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=13548' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.14358 seconds
Time After: 0.14399 seconds
Memory Before: 4,287.219 KB
Memory After: 4,287.461 KB
