Time Before: 0.00143 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00249 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00276 seconds
Time After: 0.00291 seconds
Time Before: 0.00379 seconds
Time After: 0.00659 seconds
Time Taken: 0.00280 seconds
Time Before: 0.00299 seconds
Time After: 0.01116 seconds
Time Taken: 0.00817 seconds
Time Before: 0.01306 seconds
Time After: 0.01343 seconds
Time Before: 0.01597 seconds
Time After: 0.01722 seconds
Time Before: 0.01234 seconds
Time After: 0.01748 seconds
Time Taken: 0.00513 seconds
Time Before: 0.02327 seconds
Time After: 0.02344 seconds
Time Before: 0.02582 seconds
Time After: 0.02709 seconds
End call of global.php: 0.02983283996582
Time Before: 0.03117 seconds
Time After: 0.03137 seconds
Time Before: 0.03370 seconds
Time After: 0.03518 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=135581', badlocation = 1
Time Before: 0.04937 seconds
Time After: 0.04983 seconds
Page generated in 0.048427820205688 seconds with 9 queries, spending 0.0086746215820312 doing MySQL queries and 0.039753198623657 doing PHP things.
