Time Before: 0.00976 seconds
Time After: 0.01224 seconds
Time Taken: 0.00248 seconds
Time Before: 0.01233 seconds
Time After: 0.01270 seconds
Time Before: 0.01289 seconds
Time After: 0.01303 seconds
Time Before: 0.01398 seconds
Time After: 0.01671 seconds
Time Taken: 0.00273 seconds
Time Before: 0.01312 seconds
Time After: 0.02141 seconds
Time Taken: 0.00830 seconds
Time Before: 0.02580 seconds
Time After: 0.02626 seconds
Time Before: 0.02927 seconds
Time After: 0.03050 seconds
Time Before: 0.02513 seconds
Time After: 0.03070 seconds
Time Taken: 0.00557 seconds
Time Before: 0.05235 seconds
Time After: 0.05248 seconds
Time Before: 0.06159 seconds
Time After: 0.06280 seconds
Time Before: 0.06843 seconds
Time After: 0.06858 seconds
Time Before: 0.07106 seconds
Time After: 0.07252 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=135587' WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.09127 seconds
Time After: 0.09151 seconds
