Time Before: 0.02848 seconds
Time After: 0.03836 seconds
Time Taken: 0.00989 seconds
Time Before: 0.03846 seconds
Time After: 0.03904 seconds
Time Taken: 0.00059 seconds
Time Before: 0.03932 seconds
Time After: 0.03959 seconds
Time Before: 0.04040 seconds
Time After: 0.04333 seconds
Time Taken: 0.00293 seconds
Time Before: 0.03969 seconds
Time After: 0.04868 seconds
Time Taken: 0.00899 seconds
Time Before: 0.06270 seconds
Time After: 0.06298 seconds
Time Before: 0.06567 seconds
Time After: 0.06690 seconds
Time Before: 0.06200 seconds
Time After: 0.06714 seconds
Time Taken: 0.00514 seconds
Time Before: 0.11889 seconds
Time After: 0.11906 seconds
Time Before: 0.13729 seconds
Time After: 0.13854 seconds
End call of global.php: 0.14069509506226
Time Before: 0.15473 seconds
Time After: 0.15489 seconds
Time Before: 0.15725 seconds
Time After: 0.15872 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=135620', badlocation = 1
WHERE sessionhash = 'f88c536979e48fd20a608e8efaf90f77'
Time Before: 0.18263 seconds
Time After: 0.18286 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.18156814575195 seconds with 9 queries, spending 0.0085742473602295 doing MySQL queries and 0.17299389839172 doing PHP things.
