Time Before: 0.00231 seconds
Time After: 0.00276 seconds
Time Before: 0.00283 seconds
Time After: 0.00320 seconds
Time Before: 0.00346 seconds
Time After: 0.00360 seconds
Time Before: 0.00425 seconds
Time After: 0.00637 seconds
Time Taken: 0.00212 seconds
Time Before: 0.00364 seconds
Time After: 0.00975 seconds
Time Taken: 0.00611 seconds
Time Before: 0.01155 seconds
Time After: 0.01190 seconds
Time Before: 0.01440 seconds
Time After: 0.01568 seconds
Time Before: 0.01096 seconds
Time After: 0.01597 seconds
Time Taken: 0.00501 seconds
Time Before: 0.02155 seconds
Time After: 0.02169 seconds
Time Before: 0.02350 seconds
Time After: 0.02489 seconds
Time Taken: 0.00139 seconds
End call of global.php: 0.026572942733765
Time Before: 0.02778 seconds
Time After: 0.02795 seconds
Time Before: 0.03031 seconds
Time After: 0.03182 seconds
Time Taken: 0.00151 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=135625', badlocation = 1
Time Before: 0.04577 seconds
Time After: 0.04603 seconds
Page generated in 0.044804096221924 seconds with 9 queries, spending 0.0077168941497803 doing MySQL queries and 0.037087202072144 doing PHP things.
