Time Before: 0.02845 seconds
Time After: 0.04009 seconds
Time Taken: 0.01164 seconds
Time Before: 0.04021 seconds
Time After: 0.04064 seconds
Time Before: 0.04086 seconds
Time After: 0.04097 seconds
Time Taken: 0.00010 seconds
Time Before: 0.04177 seconds
Time After: 0.04426 seconds
Time Taken: 0.00248 seconds
Time Before: 0.04102 seconds
Time After: 0.04842 seconds
Time Taken: 0.00740 seconds
Time Before: 0.06019 seconds
Time After: 0.06062 seconds
Time Before: 0.06327 seconds
Time After: 0.06445 seconds
Time Taken: 0.00118 seconds
Time Before: 0.05942 seconds
Time After: 0.06465 seconds
Time Taken: 0.00523 seconds
Time Before: 0.11688 seconds
Time After: 0.11701 seconds
Time Before: 0.13982 seconds
Time After: 0.14114 seconds
Time Taken: 0.00133 seconds
Time Before: 0.15556 seconds
Time After: 0.15572 seconds
Time Before: 0.15879 seconds
Time After: 0.16019 seconds
Time Taken: 0.00140 seconds
UPDATE session SET lastactivity = 1783172261, location = '/forums/private.php?do=newpm&explain=1&u=135669' WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.17876 seconds
Time After: 0.17923 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
