Time Before: 0.00677 seconds
Time After: 0.00942 seconds
Time Taken: 0.00265 seconds
Time Before: 0.00953 seconds
Time After: 0.01013 seconds
Time Taken: 0.00060 seconds
Time Before: 0.01043 seconds
Time After: 0.01060 seconds
Time Before: 0.01147 seconds
Time After: 0.01430 seconds
Time Taken: 0.00282 seconds
Time Before: 0.01067 seconds
Time After: 0.01909 seconds
Time Taken: 0.00842 seconds
Time Before: 0.02336 seconds
Time After: 0.02379 seconds
Time Before: 0.02643 seconds
Time After: 0.02763 seconds
Time Before: 0.02269 seconds
Time After: 0.02784 seconds
Time Taken: 0.00515 seconds
Time Before: 0.03965 seconds
Time After: 0.03982 seconds
Time Before: 0.04602 seconds
Time After: 0.04738 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.049487113952637
Time Before: 0.05431 seconds
Time After: 0.05445 seconds
Time Before: 0.05693 seconds
Time After: 0.05837 seconds
SET lastactivity = 1785314955, location = '/forums/private.php?do=newpm&explain=1&u=135707', badlocation = 1
Time Before: 0.07612 seconds
Time After: 0.07647 seconds
Page generated in 0.075006008148193 seconds with 9 queries, spending 0.0086860656738281 doing MySQL queries and 0.066319942474365 doing PHP things.
