Time Before: 0.00130 seconds
Time After: 0.00174 seconds
Time Before: 0.00181 seconds
Time After: 0.00224 seconds
Time Before: 0.00246 seconds
Time After: 0.00264 seconds
Time Before: 0.00329 seconds
Time After: 0.00605 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00268 seconds
Time After: 0.01087 seconds
Time Taken: 0.00819 seconds
Time Before: 0.01270 seconds
Time After: 0.01309 seconds
Time Before: 0.01567 seconds
Time After: 0.01689 seconds
Time Before: 0.01205 seconds
Time After: 0.01713 seconds
Time Taken: 0.00508 seconds
Time Before: 0.02369 seconds
Time After: 0.02388 seconds
Time Before: 0.02591 seconds
Time After: 0.02717 seconds
Time Before: 0.03065 seconds
Time After: 0.03085 seconds
Time Before: 0.03348 seconds
Time After: 0.03496 seconds
UPDATE session SET lastactivity = 1789019668, location = '/forums/private.php?do=newpm&explain=1&u=135720', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.04889 seconds
Time After: 0.04920 seconds
