Time Before: 0.02197 seconds
Time After: 0.02746 seconds
Time Taken: 0.00548 seconds
Time Before: 0.02755 seconds
Time After: 0.02798 seconds
Time Before: 0.02820 seconds
Time After: 0.02832 seconds
Time Before: 0.02910 seconds
Time After: 0.03160 seconds
Time Taken: 0.00250 seconds
Time Before: 0.02838 seconds
Time After: 0.03621 seconds
Time Taken: 0.00783 seconds
Time Before: 0.04448 seconds
Time After: 0.04491 seconds
Time Before: 0.04663 seconds
Time After: 0.04787 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04370 seconds
Time After: 0.04815 seconds
Time Taken: 0.00445 seconds
Memory After: 2,261.703 KB
Time Before: 0.07736 seconds
Time After: 0.07749 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.09529 seconds
Time After: 0.09653 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.10448 seconds
Time After: 0.10463 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.10722 seconds
Time After: 0.10867 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=135888', badlocation = 1 WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.12827 seconds
Time After: 0.12856 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
