Time Before: 0.00138 seconds
Time After: 0.00195 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00201 seconds
Time After: 0.00258 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00279 seconds
Time After: 0.00289 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00358 seconds
Time After: 0.00674 seconds
Time Taken: 0.00316 seconds
Time Before: 0.00294 seconds
Time After: 0.01171 seconds
Time Taken: 0.00877 seconds
Time Before: 0.01347 seconds
Time After: 0.01366 seconds
Time Before: 0.01648 seconds
Time After: 0.01768 seconds
Time Before: 0.01286 seconds
Time After: 0.01786 seconds
Time Taken: 0.00500 seconds
Time Before: 0.02291 seconds
Time After: 0.02304 seconds
Time Before: 0.02483 seconds
Time After: 0.02611 seconds
End call of global.php: 0.02773380279541
Time Before: 0.02903 seconds
Time After: 0.02916 seconds
Time Before: 0.03110 seconds
Time After: 0.03260 seconds
Time Taken: 0.00150 seconds
SET lastactivity = 1784744986, location = '/forums/private.php?do=newpm&explain=1&u=135936', badlocation = 1
Time Before: 0.04582 seconds
Time After: 0.04648 seconds
Time Taken: 0.00066 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.044847965240479 seconds with 9 queries, spending 0.0089249610900879 doing MySQL queries and 0.035923004150391 doing PHP things.
