Time Before: 0.00146 seconds
Time After: 0.00199 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00206 seconds
Time After: 0.00250 seconds
Time Before: 0.00279 seconds
Time After: 0.00292 seconds
Time Before: 0.00413 seconds
Time After: 0.00920 seconds
Time Taken: 0.00507 seconds
Time Before: 0.00301 seconds
Time After: 0.01262 seconds
Time Taken: 0.00961 seconds
Time Before: 0.01496 seconds
Time After: 0.01543 seconds
Time Before: 0.01882 seconds
Time After: 0.02025 seconds
Time Before: 0.01416 seconds
Time After: 0.02043 seconds
Time Taken: 0.00627 seconds
Time Before: 0.02707 seconds
Time After: 0.02726 seconds
Time Before: 0.02948 seconds
Time After: 0.03072 seconds
Time Before: 0.03495 seconds
Time After: 0.03517 seconds
Time Before: 0.03735 seconds
Time After: 0.03879 seconds
UPDATE session SET lastactivity = 1789115585, location = '/forums/private.php?do=newpm&explain=1&u=135952' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.05298 seconds
Time After: 0.05332 seconds
