Time Before: 0.00134 seconds
Time After: 0.00181 seconds
Time Before: 0.00189 seconds
Time After: 0.00222 seconds
Time Before: 0.00240 seconds
Time After: 0.00252 seconds
Time Before: 0.00325 seconds
Time After: 0.00541 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00256 seconds
Time After: 0.00890 seconds
Time Taken: 0.00634 seconds
Time Before: 0.01083 seconds
Time After: 0.01148 seconds
Time Taken: 0.00065 seconds
Time Before: 0.01445 seconds
Time After: 0.01567 seconds
Time Before: 0.01018 seconds
Time After: 0.01584 seconds
Time Taken: 0.00567 seconds
Time Before: 0.02085 seconds
Time After: 0.02097 seconds
Time Before: 0.02273 seconds
Time After: 0.02395 seconds
End call of global.php: 0.026237964630127
Time Before: 0.02790 seconds
Time After: 0.02808 seconds
Time Before: 0.03029 seconds
Time After: 0.03176 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=136000'
Time Before: 0.04642 seconds
Time After: 0.04677 seconds
Page generated in 0.045408964157104 seconds with 9 queries, spending 0.0078177452087402 doing MySQL queries and 0.037591218948364 doing PHP things.
