Time Before: 0.00280 seconds
Time After: 0.00407 seconds
Time Before: 0.00415 seconds
Time After: 0.00484 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00514 seconds
Time After: 0.00524 seconds
Time Taken: 0.00010 seconds
Time Before: 0.00594 seconds
Time After: 0.00981 seconds
Time Taken: 0.00387 seconds
Time Before: 0.00529 seconds
Time After: 0.01327 seconds
Time Taken: 0.00798 seconds
Time Before: 0.01531 seconds
Time After: 0.01574 seconds
Time Before: 0.01852 seconds
Time After: 0.01978 seconds
Time Before: 0.01459 seconds
Time After: 0.02002 seconds
Time Taken: 0.00543 seconds
Time Before: 0.02567 seconds
Time After: 0.02592 seconds
Time Before: 0.02894 seconds
Time After: 0.03024 seconds
End call of global.php: 0.032100915908813
Time Before: 0.03359 seconds
Time After: 0.03382 seconds
Time Before: 0.03674 seconds
Time After: 0.03820 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=136142', badlocation = 1
Time Before: 0.05315 seconds
Time After: 0.05381 seconds
Time Taken: 0.00065 seconds
Page generated in 0.052226066589355 seconds with 9 queries, spending 0.010252475738525 doing MySQL queries and 0.04197359085083 doing PHP things.
