Time Before: 0.00954 seconds
Time After: 0.01329 seconds
Time Taken: 0.00375 seconds
Time Before: 0.01337 seconds
Time After: 0.01376 seconds
Time Before: 0.01398 seconds
Time After: 0.01413 seconds
Time Before: 0.01490 seconds
Time After: 0.01705 seconds
Time Taken: 0.00215 seconds
Time Before: 0.01420 seconds
Time After: 0.02095 seconds
Time Taken: 0.00675 seconds
Time Before: 0.02660 seconds
Time After: 0.02700 seconds
Time Before: 0.02986 seconds
Time After: 0.03104 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02596 seconds
Time After: 0.03133 seconds
Time Taken: 0.00537 seconds
Time Before: 0.04574 seconds
Time After: 0.04587 seconds
Time Before: 0.05612 seconds
Time After: 0.05755 seconds
Time Before: 0.06586 seconds
Time After: 0.06601 seconds
Time Before: 0.06879 seconds
Time After: 0.07024 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=136149', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.08637 seconds
Time After: 0.08670 seconds
