Time Before: 0.01042 seconds
Time After: 0.01660 seconds
Time Taken: 0.00618 seconds
Time Before: 0.01673 seconds
Time After: 0.01719 seconds
Time Before: 0.01747 seconds
Time After: 0.01761 seconds
Time Before: 0.01845 seconds
Time After: 0.02037 seconds
Time Taken: 0.00193 seconds
Time Before: 0.01770 seconds
Time After: 0.02465 seconds
Time Taken: 0.00694 seconds
Time Before: 0.03373 seconds
Time After: 0.03428 seconds
Time Taken: 0.00055 seconds
Time Before: 0.03570 seconds
Time After: 0.03703 seconds
Time Taken: 0.00132 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.03287 seconds
Time After: 0.03726 seconds
Time Taken: 0.00439 seconds
Memory After: 2,261.703 KB
Time Before: 0.07040 seconds
Time After: 0.07061 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.21993 seconds
Time After: 0.22126 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.23422 seconds
Time After: 0.23450 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.23912 seconds
Time After: 0.24070 seconds
Time Taken: 0.00158 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=136163' WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.26602 seconds
Time After: 0.26629 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
