Time Before: 0.01230 seconds
Time After: 0.01846 seconds
Time Taken: 0.00616 seconds
Time Before: 0.01855 seconds
Time After: 0.01896 seconds
Time Before: 0.01920 seconds
Time After: 0.01934 seconds
Time Before: 0.02016 seconds
Time After: 0.02237 seconds
Time Taken: 0.00221 seconds
Time Before: 0.01942 seconds
Time After: 0.02677 seconds
Time Taken: 0.00735 seconds
Time Before: 0.03592 seconds
Time After: 0.03635 seconds
Time Before: 0.03939 seconds
Time After: 0.04077 seconds
Time Taken: 0.00138 seconds
Time Before: 0.03515 seconds
Time After: 0.04104 seconds
Time Taken: 0.00589 seconds
Time Before: 0.07043 seconds
Time After: 0.07057 seconds
Time Before: 0.09085 seconds
Time After: 0.09234 seconds
Time Before: 0.10269 seconds
Time After: 0.10284 seconds
Time Before: 0.10584 seconds
Time After: 0.10731 seconds
UPDATE session SET lastactivity = 1785305389, location = '/forums/private.php?do=newpm&explain=1&u=136175', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12664 seconds
Time After: 0.12696 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
