Time Before: 0.02128 seconds
Time After: 0.02848 seconds
Time Taken: 0.00719 seconds
Time Before: 0.02859 seconds
Time After: 0.02904 seconds
Time Before: 0.02929 seconds
Time After: 0.02943 seconds
Time Before: 0.03020 seconds
Time After: 0.03272 seconds
Time Taken: 0.00252 seconds
Time Before: 0.02952 seconds
Time After: 0.03723 seconds
Time Taken: 0.00771 seconds
Time Before: 0.04745 seconds
Time After: 0.04795 seconds
Time Before: 0.05064 seconds
Time After: 0.05185 seconds
Time Before: 0.04662 seconds
Time After: 0.05208 seconds
Time Taken: 0.00546 seconds
Time Before: 0.09021 seconds
Time After: 0.09034 seconds
Time Before: 0.10924 seconds
Time After: 0.11084 seconds
Time Taken: 0.00160 seconds
End call of global.php: 0.1136360168457
Time Before: 0.12468 seconds
Time After: 0.12519 seconds
Time Before: 0.12788 seconds
Time After: 0.12934 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=136240', badlocation = 1
Time Before: 0.15092 seconds
Time After: 0.15119 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.14955615997314 seconds with 9 queries, spending 0.0088174343109131 doing MySQL queries and 0.14073872566223 doing PHP things.
