Time Before: 0.00391 seconds
Time After: 0.00567 seconds
Time Taken: 0.00176 seconds
Time Before: 0.00576 seconds
Time After: 0.00614 seconds
Time Before: 0.00640 seconds
Time After: 0.00652 seconds
Time Before: 0.00730 seconds
Time After: 0.00956 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00657 seconds
Time After: 0.01372 seconds
Time Taken: 0.00716 seconds
Time Before: 0.01715 seconds
Time After: 0.01754 seconds
Time Before: 0.02047 seconds
Time After: 0.02169 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01644 seconds
Time After: 0.02190 seconds
Time Taken: 0.00547 seconds
Memory After: 2,261.820 KB
Time Before: 0.02979 seconds
Time After: 0.02995 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.03567 seconds
Time After: 0.03698 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.039057016372681
Time Before: 0.04129 seconds
Time After: 0.04145 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.04400 seconds
Time After: 0.04547 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789021753, location = '/forums/private.php?do=newpm&explain=1&u=136264'
Time Before: 0.06554 seconds
Time After: 0.06579 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
Page generated in 0.064370155334473 seconds with 9 queries, spending 0.0077152252197266 doing MySQL queries and 0.056654930114746 doing PHP things.
