Time Before: 0.00140 seconds
Time After: 0.00199 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00206 seconds
Time After: 0.00262 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00285 seconds
Time After: 0.00300 seconds
Time Before: 0.00364 seconds
Time After: 0.00672 seconds
Time Taken: 0.00308 seconds
Time Before: 0.00304 seconds
Time After: 0.01012 seconds
Time Taken: 0.00707 seconds
Time Before: 0.01198 seconds
Time After: 0.01237 seconds
Time Before: 0.01394 seconds
Time After: 0.01531 seconds
Time Taken: 0.00136 seconds
Time Before: 0.01140 seconds
Time After: 0.01548 seconds
Time Taken: 0.00408 seconds
Time Before: 0.02059 seconds
Time After: 0.02073 seconds
Time Before: 0.02262 seconds
Time After: 0.02383 seconds
Time Before: 0.02671 seconds
Time After: 0.02696 seconds
Time Before: 0.02907 seconds
Time After: 0.03117 seconds
Time Taken: 0.00210 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=136323', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.04661 seconds
Time After: 0.04685 seconds
