Time Before: 0.01799 seconds
Time After: 0.02373 seconds
Time Taken: 0.00574 seconds
Time Before: 0.02383 seconds
Time After: 0.02425 seconds
Time Before: 0.02446 seconds
Time After: 0.02459 seconds
Time Before: 0.02547 seconds
Time After: 0.02760 seconds
Time Taken: 0.00212 seconds
Time Before: 0.02465 seconds
Time After: 0.03180 seconds
Time Taken: 0.00715 seconds
Time Before: 0.03695 seconds
Time After: 0.03737 seconds
Time Before: 0.03889 seconds
Time After: 0.04011 seconds
Time Before: 0.03630 seconds
Time After: 0.04029 seconds
Time Taken: 0.00399 seconds
Time Before: 0.05986 seconds
Time After: 0.06000 seconds
Time Before: 0.07040 seconds
Time After: 0.07165 seconds
End call of global.php: 0.073886156082153
Time Before: 0.07899 seconds
Time After: 0.07919 seconds
Time Before: 0.08187 seconds
Time After: 0.08336 seconds
SET lastactivity = 1783055058, location = '/forums/private.php?do=newpm&explain=1&u=136417'
Time Before: 0.10030 seconds
Time After: 0.10058 seconds
Page generated in 0.099291086196899 seconds with 9 queries, spending 0.0076589584350586 doing MySQL queries and 0.091632127761841 doing PHP things.
