Time Before: 0.01467 seconds
Time After: 0.02088 seconds
Time Taken: 0.00621 seconds
Time Before: 0.02097 seconds
Time After: 0.02141 seconds
Time Before: 0.02161 seconds
Time After: 0.02183 seconds
Time Before: 0.02259 seconds
Time After: 0.02478 seconds
Time Taken: 0.00219 seconds
Time Before: 0.02188 seconds
Time After: 0.02922 seconds
Time Taken: 0.00734 seconds
Time Before: 0.03659 seconds
Time After: 0.03703 seconds
Time Before: 0.04046 seconds
Time After: 0.04180 seconds
Time Taken: 0.00134 seconds
Time Before: 0.03587 seconds
Time After: 0.04203 seconds
Time Taken: 0.00617 seconds
Time Before: 0.07819 seconds
Time After: 0.07836 seconds
Time Before: 0.09694 seconds
Time After: 0.09827 seconds
Time Taken: 0.00133 seconds
Time Before: 0.10923 seconds
Time After: 0.10947 seconds
Time Before: 0.11175 seconds
Time After: 0.11323 seconds
UPDATE session SET lastactivity = 1784791779, location = '/forums/private.php?do=newpm&explain=1&u=136488', badlocation = 1 WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.13298 seconds
Time After: 0.13337 seconds
