Time Before: 0.00250 seconds
Time After: 0.00303 seconds
Time Taken: 0.00053 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.00311 seconds
Time After: 0.00365 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.00386 seconds
Time After: 0.00396 seconds
Time Taken: 0.00010 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.00457 seconds
Time After: 0.00676 seconds
Time Taken: 0.00219 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.00401 seconds
Time After: 0.01062 seconds
Time Taken: 0.00660 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.01314 seconds
Time After: 0.01357 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.01515 seconds
Time After: 0.01633 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.01237 seconds
Time After: 0.01653 seconds
Time Taken: 0.00416 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.02299 seconds
Time After: 0.02312 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.78548 seconds
Time After: 0.78739 seconds
Time Taken: 0.00191 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.79626 seconds
Time After: 0.79639 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.79861 seconds
Time After: 0.80014 seconds
Time Taken: 0.00153 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=136506' WHERE sessionhash = '39fd84efec1f1104044a97f8301439e1'
Time Before: 0.81347 seconds
Time After: 0.81369 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
