Time Before: 0.01221 seconds
Time After: 0.01409 seconds
Time Taken: 0.00188 seconds
Time Before: 0.01424 seconds
Time After: 0.01465 seconds
Time Before: 0.01489 seconds
Time After: 0.01508 seconds
Time Before: 0.01605 seconds
Time After: 0.01855 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01515 seconds
Time After: 0.02318 seconds
Time Taken: 0.00802 seconds
Time Before: 0.02809 seconds
Time After: 0.02848 seconds
Time Before: 0.03165 seconds
Time After: 0.03289 seconds
Time Before: 0.02740 seconds
Time After: 0.03311 seconds
Time Taken: 0.00571 seconds
Time Before: 0.04914 seconds
Time After: 0.04928 seconds
Time Before: 0.05879 seconds
Time After: 0.06005 seconds
End call of global.php: 0.063106060028076
Time Before: 0.06855 seconds
Time After: 0.06874 seconds
Time Before: 0.07168 seconds
Time After: 0.07316 seconds
SET lastactivity = 1783059036, location = '/forums/private.php?do=newpm&explain=1&u=136507'
Time Before: 0.09082 seconds
Time After: 0.09114 seconds
Memory Before: 4,289.063 KB
Memory After: 4,289.289 KB
Page generated in 0.089631080627441 seconds with 9 queries, spending 0.0081496238708496 doing MySQL queries and 0.081481456756592 doing PHP things.
