Time Before: 0.00142 seconds
Time After: 0.00188 seconds
Time Before: 0.00195 seconds
Time After: 0.00247 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00269 seconds
Time After: 0.00282 seconds
Time Before: 0.00349 seconds
Time After: 0.00558 seconds
Time Taken: 0.00209 seconds
Time Before: 0.00287 seconds
Time After: 0.00899 seconds
Time Taken: 0.00612 seconds
Time Before: 0.01082 seconds
Time After: 0.01122 seconds
Time Before: 0.01283 seconds
Time After: 0.01401 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01021 seconds
Time After: 0.01419 seconds
Time Taken: 0.00398 seconds
Time Before: 0.01909 seconds
Time After: 0.01922 seconds
Time Before: 0.02117 seconds
Time After: 0.02244 seconds
End call of global.php: 0.024109125137329
Time Before: 0.02535 seconds
Time After: 0.02548 seconds
Time Before: 0.02751 seconds
Time After: 0.02898 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=136541', badlocation = 1
Time Before: 0.04270 seconds
Time After: 0.04296 seconds
Page generated in 0.041712045669556 seconds with 9 queries, spending 0.0075857639312744 doing MySQL queries and 0.034126281738281 doing PHP things.
