Time Before: 0.00139 seconds
Time After: 0.00190 seconds
Time Before: 0.00196 seconds
Time After: 0.00249 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00275 seconds
Time After: 0.00290 seconds
Time Before: 0.00360 seconds
Time After: 0.00665 seconds
Time Taken: 0.00304 seconds
Time Before: 0.00295 seconds
Time After: 0.01010 seconds
Time Taken: 0.00716 seconds
Time Before: 0.01211 seconds
Time After: 0.01250 seconds
Time Before: 0.01397 seconds
Time After: 0.01519 seconds
Time Before: 0.01151 seconds
Time After: 0.01536 seconds
Time Taken: 0.00385 seconds
Time Before: 0.02064 seconds
Time After: 0.02079 seconds
Time Before: 0.02303 seconds
Time After: 0.02435 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.026090860366821
Time Before: 0.02752 seconds
Time After: 0.02776 seconds
Time Before: 0.02989 seconds
Time After: 0.03148 seconds
Time Taken: 0.00159 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=136580'
Time Before: 0.04384 seconds
Time After: 0.04420 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.042947053909302 seconds with 9 queries, spending 0.0089826583862305 doing MySQL queries and 0.033964395523071 doing PHP things.
