Time Before: 0.02715 seconds
Time After: 0.03614 seconds
Time Taken: 0.00899 seconds
Time Before: 0.03625 seconds
Time After: 0.03666 seconds
Time Before: 0.03690 seconds
Time After: 0.03703 seconds
Time Before: 0.03789 seconds
Time After: 0.04069 seconds
Time Taken: 0.00280 seconds
Time Before: 0.03710 seconds
Time After: 0.04506 seconds
Time Taken: 0.00796 seconds
Time Before: 0.05331 seconds
Time After: 0.05372 seconds
Time Before: 0.05622 seconds
Time After: 0.05744 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05269 seconds
Time After: 0.05768 seconds
Time Taken: 0.00499 seconds
Memory After: 2,261.820 KB
Time Before: 0.09981 seconds
Time After: 0.09995 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.12732 seconds
Time After: 0.12862 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.14364 seconds
Time After: 0.14377 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.14670 seconds
Time After: 0.14897 seconds
Time Taken: 0.00227 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788978236, location = '/forums/private.php?do=newpm&explain=1&u=136585', badlocation = 1 WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.17121 seconds
Time After: 0.17715 seconds
Time Taken: 0.00594 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
