Time Before: 0.00143 seconds
Time After: 0.00192 seconds
Time Before: 0.00199 seconds
Time After: 0.00268 seconds
Time Taken: 0.00068 seconds
Time Before: 0.00296 seconds
Time After: 0.00309 seconds
Time Before: 0.00386 seconds
Time After: 0.00692 seconds
Time Taken: 0.00305 seconds
Time Before: 0.00315 seconds
Time After: 0.01026 seconds
Time Taken: 0.00711 seconds
Time Before: 0.01209 seconds
Time After: 0.01254 seconds
Time Before: 0.01509 seconds
Time After: 0.01627 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01156 seconds
Time After: 0.01645 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02345 seconds
Time After: 0.02358 seconds
Time Before: 0.02528 seconds
Time After: 0.02654 seconds
Time Before: 0.02948 seconds
Time After: 0.02964 seconds
Time Before: 0.03165 seconds
Time After: 0.03308 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=136593' WHERE sessionhash = 'b1e9f976e3e130f3a0e1c3e688e54b68'
Time Before: 0.04553 seconds
Time After: 0.04582 seconds
