Time Before: 0.00236 seconds
Time After: 0.00356 seconds
Time Before: 0.00363 seconds
Time After: 0.00419 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00445 seconds
Time After: 0.00458 seconds
Time Before: 0.00543 seconds
Time After: 0.00765 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00465 seconds
Time After: 0.01330 seconds
Time Taken: 0.00865 seconds
Time Before: 0.01574 seconds
Time After: 0.01619 seconds
Time Before: 0.01890 seconds
Time After: 0.02012 seconds
Time Before: 0.01498 seconds
Time After: 0.02037 seconds
Time Taken: 0.00539 seconds
Time Before: 0.02647 seconds
Time After: 0.02670 seconds
Time Before: 0.02851 seconds
Time After: 0.02971 seconds
End call of global.php: 0.031432151794434
Time Before: 0.03322 seconds
Time After: 0.03378 seconds
Time Before: 0.03595 seconds
Time After: 0.03760 seconds
Time Taken: 0.00165 seconds
SET lastactivity = 1789108659, location = '/forums/private.php?do=newpm&explain=1&u=13675', badlocation = 1
Time Before: 0.05184 seconds
Time After: 0.05931 seconds
Time Taken: 0.00747 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
Page generated in 0.050873041152954 seconds with 9 queries, spending 0.015700101852417 doing MySQL queries and 0.035172939300537 doing PHP things.
