Time Before: 0.01200 seconds
Time After: 0.02030 seconds
Time Taken: 0.00830 seconds
Time Before: 0.02042 seconds
Time After: 0.02127 seconds
Time Taken: 0.00084 seconds
Time Before: 0.02167 seconds
Time After: 0.02183 seconds
Time Before: 0.02258 seconds
Time After: 0.02552 seconds
Time Taken: 0.00294 seconds
Time Before: 0.02189 seconds
Time After: 0.02982 seconds
Time Taken: 0.00793 seconds
Time Before: 0.03715 seconds
Time After: 0.03755 seconds
Time Before: 0.04028 seconds
Time After: 0.04153 seconds
Time Before: 0.03644 seconds
Time After: 0.04175 seconds
Time Taken: 0.00531 seconds
Time Before: 0.07645 seconds
Time After: 0.07659 seconds
Time Before: 0.08741 seconds
Time After: 0.08866 seconds
Time Before: 0.10196 seconds
Time After: 0.10210 seconds
Time Before: 0.10433 seconds
Time After: 0.10584 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1776567472, location = '/forums/private.php?do=newpm&explain=1&u=136779', badlocation = 1 WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.12486 seconds
Time After: 0.12520 seconds
