Time Before: 0.00201 seconds
Time After: 0.00255 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00262 seconds
Time After: 0.00301 seconds
Time Before: 0.00325 seconds
Time After: 0.00340 seconds
Time Before: 0.00412 seconds
Time After: 0.00762 seconds
Time Taken: 0.00349 seconds
Time Before: 0.00348 seconds
Time After: 0.01203 seconds
Time Taken: 0.00855 seconds
Time Before: 0.01387 seconds
Time After: 0.01434 seconds
Time Before: 0.01785 seconds
Time After: 0.01932 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01316 seconds
Time After: 0.01957 seconds
Time Taken: 0.00641 seconds
Memory After: 2,261.820 KB
Time Before: 0.02443 seconds
Time After: 0.02459 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02680 seconds
Time After: 0.02804 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.030576944351196
Time Before: 0.03193 seconds
Time After: 0.03213 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03514 seconds
Time After: 0.03661 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789023028, location = '/forums/private.php?do=newpm&explain=1&u=136786', badlocation = 1
Time Before: 0.05005 seconds
Time After: 0.05041 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
Page generated in 0.049124002456665 seconds with 9 queries, spending 0.0093777179718018 doing MySQL queries and 0.039746284484863 doing PHP things.
