Time Before: 0.00174 seconds
Time After: 0.00226 seconds
Time Before: 0.00238 seconds
Time After: 0.00342 seconds
Time Taken: 0.00104 seconds
Time Before: 0.00410 seconds
Time After: 0.00468 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00590 seconds
Time After: 0.00811 seconds
Time Taken: 0.00222 seconds
Time Before: 0.00473 seconds
Time After: 0.01153 seconds
Time Taken: 0.00680 seconds
Time Before: 0.01422 seconds
Time After: 0.01461 seconds
Time Before: 0.01725 seconds
Time After: 0.01844 seconds
Time Before: 0.01347 seconds
Time After: 0.01868 seconds
Time Taken: 0.00520 seconds
Time Before: 0.02404 seconds
Time After: 0.02420 seconds
Time Before: 0.02597 seconds
Time After: 0.02719 seconds
End call of global.php: 0.028836965560913
Time Before: 0.03001 seconds
Time After: 0.03016 seconds
Time Before: 0.03212 seconds
Time After: 0.03358 seconds
SET lastactivity = 1789080422, location = '/forums/private.php?do=newpm&explain=1&u=136808', badlocation = 1
Time Before: 0.04916 seconds
Time After: 0.04944 seconds
Page generated in 0.048228979110718 seconds with 9 queries, spending 0.0086970329284668 doing MySQL queries and 0.039531946182251 doing PHP things.
